Aircondition Blower Problem - Need help
Old Jun 10, 2010 | 08:53 AM
LR03NJ's Avatar
Default Aircondition Blower Problem - Need help
I just got a climate control ECU and replaced it thinking it was the problem. Checked all fuses related to ac and heater blower, all checked working. Any other places I missed. AC compressor working and cooling but the blower isnt. Is it easy to replace the blower if that is broken? Any suggestions about trouble shooting the problem? Any, relay related to the blower? Please help, too hot to drive. Thanks
Old Jun 10, 2010 | 08:58 AM
LR03NJ's Avatar
Sorry, Need to add to previous post. Also the heater is working but not air coming out. Lastly, do they have the same blower for AC and heater? Thanks
Old Jun 10, 2010 | 09:32 AM
lipadj46's Avatar
Pull out the fan jump it with a 12 volt source. If it does not work replace it. Rave CD has the details on how to remove.
Old Jun 10, 2010 | 10:50 AM
ROVERTECH15's Avatar
and if it does run when u power it the blower motor resistor is most likely bad
Old Jun 10, 2010 | 11:24 AM
LR03NJ's Avatar
I saw the blower underneath the passenger side. Saw a RED and BLUE power leads, are those the main power wires to blower. I have the RAVE thing but cant find the instructions but the removal of the whole unit. Anyway, Do I really have to remove the blower to test it? Or, I can just tap to the blower leads and jump it to a 12 volt source? How often does those fan need replacing. The dealer replaced it 3 years ago as the work sheet I found mentioned. Thanks again.
Old Jun 10, 2010 | 11:27 AM
LR03NJ's Avatar
If it works, which is more likely to replace. I saw 2 separate component which is identical on RAVE manual the resistor and the blower relay. Anyways to test relays?
Old Jun 10, 2010 | 11:49 AM
okdiscoguy's Avatar
Pull the plug to the blower. Test to see if you are getting power to the blower with a meter on the 2 wires you unplug. If you are getting the right voltage, jumper voltage to the motor just to double check. If you are not getting the right voltage, still jump the motor. That will tell you where to go next.
Old Jun 10, 2010 | 12:06 PM
LR03NJ's Avatar
I did precisely that. Im looking for a wire to jump it right now. I saw that there is power going to the leads when the AC is on. I'll keep you posted. I will test the blower separately. Thanks
Old Jun 10, 2010 | 12:25 PM
LR03NJ's Avatar
Hi Guys, Just tested the blower by itself and its working just fine. Loud and strong. Whats next? Resistor or relay?
Old Jun 10, 2010 | 02:07 PM
okdiscoguy's Avatar
How much power is going to the leads? did you test voltage between the 2 leads? pretty sure the resistors are on the negative side..
