Akebono Pads Done! But have questions..
I just installed the Akebono pads all the way around. Prior to the install I had a rough pedal. It felt like it was grinding as if the pads were bad. I had a lot of dust and squealing. Today I pulled the old pads out only to find out that they were over half worn and wearing perfect on all sides. The rotors are perfect, I did a full three bottle flush, and checked all the lines. Any thought on the feeling and sounds even thought the pads were good. Is it just the crap pads that were on it? I did have a hint of a leak when I pushed in one of the calipers. I let it sit and watched in for over an hour while I finished the rest of the pads. It was not leaking any more after that. I drove about 80 miles home with zero problems. I have Let it sit for several hours now and see no signs of a leak. I will check it again in the morning. Keep you posted. Has anyone had this problem, should I be worry more about it.
TRIARII
12-01-2012 11:46 AM
