All dome lights stay on while driving.
Old Mar 12, 2022 | 08:14 PM
krustacean's Avatar
Default All dome lights stay on while driving.
Eventually they time out. Why is this happening? I am thinking the fact that my drivers door actuator will unlock but won't lock using the fob? Also when I use the inside rocker switch the drivers lock doesn't lock. I have to manually lock with key and then I get a single horn warning that I'm guessing something isn't secure?
Old Mar 13, 2022 | 08:58 AM
Massrover's Avatar
Single toot after locking should indicate an open door. Rear cargo door is possible culprit take a look again at all of the doors.
Old Mar 13, 2022 | 09:02 AM
krustacean's Avatar
I will rescan once again. I’m sure there’s a sticky switch somewhere! Ugh
Old Mar 19, 2022 | 07:51 AM
JUKE179r's Avatar
This happens to me when my wife drives my Disco and doesn’t forcefully shut the rear cargo door.
Old Mar 19, 2022 | 08:27 AM
The Deputy's Avatar
Agree, rear barn door latches somewhat without being totally closed. It takes a hefty swing to get it to latch properly. If you are getting a single beep, one of the five doors or hood is not closed properly...or you have a bad switch on one.
Old Mar 19, 2022 | 10:57 AM
nashvegas's Avatar
Could also be hood alarm switch. Give it a chk.
The single beep means you probably just have a door open signal that you will want to trace down and solve -- if you didn't have the beep I'd say you might have corrosion in your interior (under drivers side) fusebox.
Old Mar 20, 2022 | 05:34 PM
krustacean's Avatar
Yes, I thought I was on to something while inspecting the hood alarm switch I actually got the truck to lock properly using the fob, no honk. The hood switch wasn't quite tall enough to meet up with the bonnet and switch to 'closed' as there was a part missing (the rubber boot). So I jumped the connector and "thought" I had the issue isolated on that switch ( I even did a happy dance). It worked five time and eventually I was back to where I started with it giving me the honk again. I gave it my middle finger and went in to have dinner. That's my day today.
attworth
Mar 24, 2019 07:55 PM
mooni
Jan 5, 2015 09:38 AM
mzcharj
Oct 27, 2014 02:23 PM
sc_mark
Aug 8, 2012 01:14 PM
corbin
Dec 20, 2009 07:23 AM
