And all the possible sources for over fueling are?
Old 04-20-2011 | 10:38 PM
Originally Posted by Cosmic88
And by the way, ain't nothin' snooty about anything coming out of Comstock, Michigan. (Right Spike) Just Damn good brew.
EXACTLY!!
I think I might just pick up some Bell's for this weekend.
Old 04-20-2011 | 11:23 PM
thospb's Avatar
Have you looked at the Engine data while it is running? Does the Engine Coolant Temp (ETC) register full operating temp? If not, could your T-stat be stuck open? Or could the ETC sensor be faulty? This will cause the ECM to think the engine is cold and keep it running rich.
Old 04-21-2011 | 11:48 AM
DiscoIIBrandon's Avatar
I have not looked at any other engine data live while running, just the newest o2 sensors once installed to confirm they were working properly.
I did try and check the ECT sensor with a multimeter (which is hard to get at and get a reading even with the alt out of the way), but my test ended up inconclusive! I did get a reading from it that it was functioning, but I'm not sure beyond that.
I suppose the t-stat could be stuck open, is there an easier way to check it then by yanking off the hoses and losing coolant? lol
I'm hoping to spend saturday morning going over all possibilities to figure this out. As of now I plan on checking: plugs, fuel pressure, ECT sensor, and maybe t-stat.
I've read up on the fuel pressure regulator and that seems like another possible cause, but will be a bit of a bugger to get to and check, so I will leave that for last.
Thanks, DIIB
ChrisDiscoii
07-10-2012 07:14 PM
SolbergFanBoi
03-05-2012 08:05 PM
Snafu / Disco Fries
06-20-2011 09:26 AM
jarkalina
02-15-2008 09:10 AM
Morgan
08-14-2007 09:15 PM
Quick Reply: And all the possible sources for over fueling are?
