Alternate source for idler pulleys?
It's a beautiful fall day here in Fargo and I'd like to use it to replace the idler pulleys on my Discovery (2001 no ACE or Secondary Air). Unfortunately none of the local auto parts stores have a listing for the part.
Does anyone know of a vehicle with a idler pull that could be used instead of the LR pulley? I'd love to replace them both today, but it seems like I might have to just suck it up and order them online.
I've already replaced the tensioner pulley and belt, but I still have a belt squeal so I'd like to do the other two as well.
Thanks!
Thanks!
Thanks. I ended up replacing the 70mm pulley with a NAPA Part: NBH38018. The pully is a tiny bit narrower at 25mm so I'm still going to order one from Land Rover. I think I'm going to press a new bearing into the 80mm pulley when the bearing place opens on Monday.
