Alternator Wiring Harness Routing
Old Mar 25, 2020 | 09:39 PM
robert.juric's Avatar
Default Alternator Wiring Harness Routing
Does anyone have a picture of the proper, factory, way the wiring harness should be routed from the alternator area down to the starter?
I need to restore the split-loom and route mine properly down the the front of the engine.
Old Mar 29, 2020 | 11:56 AM
Anyone have a pic of what they think is the best way to route the wires, even if it’s not factory?
Old Mar 29, 2020 | 01:54 PM
XRAD's Avatar
like this?
Old Mar 29, 2020 | 03:17 PM
Thanks for that.
For the section up to the alternator, do you route it front of or behind the oil fill neck?
Old Mar 29, 2020 | 04:03 PM
Best4x4's Avatar
It routes usually behind the Oil Filler neck then across and over to the Fuse Block under the hood (Brown thick cable in the pic). You should also have a black ground lead connecting near or just above the belt tensioner. The large other cable = starter cable.
Old Mar 29, 2020 | 04:04 PM
XRAD's Avatar
behind. Install the wires onto alternator before installing alternator into bracket....
Ben Matheson
Apr 14, 2019 04:24 PM
Tercan
May 2, 2010 09:24 AM
tornado_735
Jun 5, 2009 10:22 AM
tornado_735
Apr 27, 2009 08:25 AM
Coovie
Mar 11, 2006 02:51 PM
