am I playing with fire?
Old Mar 12, 2014 | 02:56 PM
zeroone's Avatar
Default am I playing with fire?
As part of an upcoming summer rover project I am removing the headliner to have it repaired. While it is out I have every intention of repairing all the leaks and both sunroofs. Today I couldn't help my self and decided to go out and poke at the rover. I pulled down the little access panel and did the caveman thing on the front motor.. it started to work.. I opened and closed it several times. Figure in the motor is shot and probably on borrowed time, I closed it. Did the same for the rear.. nada? I hear clicks and what not coming from the control box up front. Am I safe to assume the motor is toast? I also read through lots of threads.. I kept reading about converting them to a manual crank, my xr4ti had this.. it was awesome. How can it be done?
Old Mar 12, 2014 | 03:15 PM
Dan7's Avatar
Good info on the subject:
https://landroverforums.com/forum/di...f-crank-33745/
Basically, you can use any 4mm allen wrench on the electric versions to open/close them manually.
This:
Land Rover Discovery Genuine OEM Factory Sunroof Manual Handle
is basically an allen wrench with a egrnomic plastic handle specifically for the sunroof.
Old Mar 12, 2014 | 03:41 PM
jamestfl's Avatar
shut the front door! now that is really cool. now I can have some sunroofs that work, thanx all.
Old Mar 12, 2014 | 03:56 PM
zeroone's Avatar
I tried the Allen wrench on the rear motor... b that one is stiff as a brick. No moment what so ever. Opened the front because I couldn't help myself.. started to rain right after. Closed it right up.
Old Mar 12, 2014 | 09:34 PM
LRLawyer's Avatar
I believe you can swap out the motors from the front and back. Put the back motor in the front and see if it works.
Old Mar 12, 2014 | 10:18 PM
zeroone's Avatar
This is going to happen as well. Especially since the rubber floor mats where filling with water last time I checked. Headliner is coming out monday.
Buggington
Jan 19, 2019 08:12 PM
edmason
Defender
Aug 29, 2011 04:31 PM
letmec1
Sights N Sounds
Feb 14, 2010 12:50 PM
JBravoM3
Jul 25, 2008 11:36 PM
trinidev
Aug 21, 2005 06:40 AM
