Amigos.........
Old Feb 9, 2011 | 08:07 AM
dbuck's Avatar
4th Gear
Default Amigos.........
Hey,
so I have the three amigos on and off intermediately, reading through here I thought it made sense to buy the ABS Amigo from RSW and check it out rather than taking to shop.....
So I have current logged Fault 114.......
Previous active fault 022....
I am going to try the ABS option B fix as soon as I can, if that works I think I will have the issue resolved for a fraction of the price of taking to a dealer....
So, I will update here as I go.
Thanks to RSW for building the ABS Amigo (it works a treat by the look of it)
Thanks to this forum for the write ups and great detailed discussions....let's see if I can fix this thing LoL.....
Old Feb 9, 2011 | 01:20 PM
tbesselman's Avatar
I just did it (josh's ground bypass) and had the same fault - the other thing you should do is replace the shuttle valve with an upgraded svc and o-rings from Falconworks - mine is working perfect now...
Here is the link: Discomike reccomended this and I;m glad I went the extra mile http://www.jewellamberoil.com/sales/...roducts_id=190
Old Feb 9, 2011 | 02:44 PM
dbuck's Avatar
4th Gear
Tom,
Would you replace the SVS even if it tested ok as per the instructions or perhaps just replace seals?
majrmike
Jun 6, 2016 03:05 PM
cammyr01
Jan 5, 2015 02:42 AM
iplayblues4u@comcast.net
Jan 6, 2010 08:43 AM
offroader
Jun 16, 2007 12:31 AM
skrams
Feb 7, 2007 11:50 PM
