Amigos....aaaahhhhhh!!!!!$&@"
Old Feb 3, 2013 | 10:27 AM
hilltoppersx's Avatar
Originally Posted by AdrenalinPlease
Yes sir! All four lights are on steady and I topped off brake fluid. Abs and TC do NOT work, I have a feeling that one the wheel sensors is pulled out of the hub or a wire is stretched. Do the sensors just push into the hub?
the stock sensors are part of the hub you cant easily just pull it out it would tear. they can bend and if out of range will not send a signal. this had nothing to do with ur lift.
Old Feb 3, 2013 | 02:33 PM
AdrenalinPlease's Avatar
Is it that coincidental? It wasn't that they came on right after the install, I drove all day after the install with no problem, then I went over a lot of continuous dips at an exciting pace and the lights kicked on during that process. Code p1590 popped on as a pending initially and now it's just a trouble code but no engine light.
Old Feb 3, 2013 | 02:37 PM
It's a 3" lift mike, I zip tied the brackets that hold the brake lines and sensor wires so that they have a bit more leg room.
jycsalas
May 23, 2019 03:02 PM
jmason
Mar 12, 2013 08:08 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
caustin
Feb 15, 2009 04:14 PM
