Amigos can to say hola briefly
Turned on the truck last night and the Amigos were there. Restarted the truck and they were gone. Had 4 trips after and didn't come back. It was cold last night, so I'm thinking maybe something to do with that? I put new front pads and bleed the brakes a couple weeks back, but drove it a tin since then.
My question is, if I had them scanned with the amigo scanner, are they stored in memory? Also, should it come on when I'm driving, it pretty much means I have no abs or traction control, right? For the 4wd, does it greatly impact performance? I ask as there looks to be a bit of snow and sleet in the forecast for the coming week, and this is my ski truck.
Thanks!
Thanks!
This is not happening because of the cold. I would suggest that you get it read with a abs computer and get whatever is wrong fixed there are about 18 different things so guessing is not a cheap decision and yes when the lights are lit up you will probably not have them. Not having the abs and tc could make winter driving dangerous.
I have a friend who should have a scanner, but likely not going to get down by him until after the holidays. I can deal and actually prefer to have no abs or tc for the snow...as long as the 4wd works! Hope the lights don't come back but would rather be proactive.
That is what I thought Mike, thanks. So I guess just carry on until when/if they choose to show back up? If there is anything you could think of to check out (connections, etc) which could have caused them to show up the once? Only thing touched in the system was back pads 2 months ago and front pads 2 weeks ago.
Thanks!
Thanks!
Senormac
04-29-2015 08:28 AM
