RPM Dropping Briefly
Old Sep 18, 2012 | 10:30 PM
Aus-trek's Avatar
Default RPM Dropping Briefly
My wife is reporting an intermittent problem with our '98D1 petrol V8. 3 or 4 times a week when driving (engine warm) the rev's will suddenly drop to around 1k for 2 or 3 seconds then increase then drop again then everything is fine (haven't experienced it myself). I suspect something with the fuel system but not sure. We run it on 95 or 98 fuel. Any ideas?
Old Sep 18, 2012 | 11:59 PM
EricTyrrell's Avatar
I bet your VSS is failing. It may think you're going too fast and cut power to one bank of cylinders. If you have an ultragauge you can look at the mph live readout to see if it's faulty. I've had this happen.
Old Sep 19, 2012 | 05:50 PM
Aus-trek's Avatar
Thanks. I'll swap it out and see what happens.
Old Sep 19, 2012 | 08:21 PM
TPS is bad, there was actually a TSB on this issue.
Replace your throttle position sensor.
It is dropping to idle speed.
Old Oct 17, 2012 | 06:12 PM
Aus-trek's Avatar
Swapped the VSS but the problem remains. Will try the TPS and let you know how it goes. Thanks for all the help.
Old Oct 17, 2012 | 08:20 PM
If revs might be going to zero on tach but still actually turning those rpms on the engine consider a bad alternator.
Old Oct 17, 2012 | 08:58 PM
Its a bad TPS, like I already told him.
Old Oct 31, 2012 | 04:21 AM
Aus-trek's Avatar
More suggestions here. Follow the link for the final answer (I hope).
https://landroverforums.com/forum/di...mystery-53647/
mtrdrms
Jan 2, 2013 08:35 AM
Snafu / Disco Fries
Dec 24, 2012 12:08 PM
willb285
Jul 24, 2010 04:54 AM
kean
Mar 3, 2009 07:28 PM
willb285
May 17, 2006 02:48 PM
