Amigos can to say hola briefly
Old Dec 23, 2012 | 05:31 PM
Snafu / Disco Fries's Avatar
Default Amigos can to say hola briefly
Turned on the truck last night and the Amigos were there. Restarted the truck and they were gone. Had 4 trips after and didn't come back. It was cold last night, so I'm thinking maybe something to do with that? I put new front pads and bleed the brakes a couple weeks back, but drove it a tin since then.
My question is, if I had them scanned with the amigo scanner, are they stored in memory? Also, should it come on when I'm driving, it pretty much means I have no abs or traction control, right? For the 4wd, does it greatly impact performance? I ask as there looks to be a bit of snow and sleet in the forecast for the coming week, and this is my ski truck.
Thanks!
Old Dec 23, 2012 | 05:54 PM
lr2001silver's Avatar
Banned
This is not happening because of the cold. I would suggest that you get it read with a abs computer and get whatever is wrong fixed there are about 18 different things so guessing is not a cheap decision and yes when the lights are lit up you will probably not have them. Not having the abs and tc could make winter driving dangerous.
Old Dec 23, 2012 | 06:53 PM
So those codes are stored then and don't go away? I only said the cold as the truck gets grumpy in the cold. Turn signals take a while to activate, power steering whines a bit and the trans doesn't like to shift into overdrive. Those all get better after a few minutes when she is up to temp.
I have a friend who should have a scanner, but likely not going to get down by him until after the holidays. I can deal and actually prefer to have no abs or tc for the snow...as long as the 4wd works! Hope the lights don't come back but would rather be proactive.
Old Dec 24, 2012 | 07:11 AM
The codes are not stored, you can only read any code, including the 3 amigos when the lights are actually on.
Old Dec 24, 2012 | 10:01 AM
That is what I thought Mike, thanks. So I guess just carry on until when/if they choose to show back up? If there is anything you could think of to check out (connections, etc) which could have caused them to show up the once? Only thing touched in the system was back pads 2 months ago and front pads 2 weeks ago.
Thanks!
Old Dec 24, 2012 | 12:08 PM
bostongrun's Avatar
I had intermittent 3 Amigos but after I got a new battery the problem went away and never came back? Maybe a failing battery allows voltage to drop too low when braking?
Senormac
Apr 29, 2015 08:28 AM
Aus-trek
Oct 31, 2012 04:21 AM
starcraft
Mar 31, 2008 08:35 AM
Landdaddy
Jun 13, 2006 11:27 PM
