Is this amount of steering play normal?
Just replaced the entire suspension last week and wondering if this amount of steering play is normal. Never noticed it before. Most obvious with the engine off and just parked.
Also, it’s likely to a bit more worn in the middle of travel (wheel centred) as that’s where it gets most of its use. I don’t know the procedure on the D2, on but other vehicles I’ve turned the wheel away from centre to adjust it.
Mine has about that much or a little less play in the wheel while the engines off but I'm pretty sure most of my suspension is original. But I've been told that Discoverys came from the factory with a little bit of play in the wheel like that.
