another 02 thread
Old Feb 27, 2010 | 10:47 PM
she-made-me-do-it's Avatar
Default another 02 thread
i know i know u shouldnt buy unaversal 02s but the tags are going to die dont have 500 to get the right ones so can any one help me with the wires i dont under stand the rave manual diagrams please help?
Old Feb 28, 2010 | 09:21 AM
What are you trying to understand?
The new O2's will come with directions and the connector to tap into your old wire harness.
Old Feb 28, 2010 | 03:08 PM
sorry the new 02s have 2 whte, 1 grey, 1 back the harness from the old 1s have 1 red, 1 blck, 1 yellow, and 1 white i need to know whitch ones are the power, ground, and heaters
Old Feb 28, 2010 | 04:28 PM
What do the instructions say?
I used a universal one on my wifes car, same thing, 4 different colored wires but the instructions were clear as what goes to what.
That was a year ago so I dont remember.
Old Mar 1, 2010 | 08:50 AM
the new 02s come with their instructions but i need to know wich wires are the heaters, pcm andgroung for the disco side i dont understand the rave manual diagram if anyone could help me with that it would be great.
Old Mar 1, 2010 | 10:27 AM
My instructions said, for example, "connect gray wire on the new O2 to the red wire on your old wire harness. Then connect the white wire to the black wire..." etc.
So I did not need to know which color was for what on my old harness.
I just assumed that all universal O2 instructions were that way.
Old Mar 5, 2010 | 09:13 AM
fiatspider75@hotmail.com's Avatar
Default o2 wire colors
Maybe this will help, I copied this from the manual.
Each of the heated oxygen sensors have a four pin connector with the following wiring details:
l Sensor signal ground (grey wire – connects to engine management ECM)
l Sensor signal (black wire – connects to engine management ECM)
l Heater drive (white wire – connects to engine management ECM)
l Heater supply (white wire – connects to fuse 2, underbonnet fuse box)
Here's a universal diagram I found, I color coded what LR wire should go to each universal wire.
UNIVERSAL OXYGEN SENSOR WIRING DIAGRAM
SIGNAL
GROUND
HEATER
HEATER
AC DELCO
PURPLE
TAN
BROWN
BROWN
BOSCH
BLACK
GREY
WHITE
WHITE
BWD 1
BLACK
GREY
WHITE
WHITE
BWD 2
PURPLE
GREY
WHITE
WHITE
BWD 3
PURPLE
TAN
BROWN
BROWN
DELPHI 1
PURPLE
TAN
BROWN
BROWN
DELPHI 2
BLACK
GREY
PURPLE
WHITE
DENSO
BLUE
WHITE
BLACK
BLACK
HONDA 1
WHITE
GREEN
BLACK
BLACK
HONDA 2
BLUE
WHITE
BLACK
BLACK
NTK
BLACK
GREY
WHITE
WHITE
SMP/STD
BLACK
GREY
WHITE
WHITE
TOYOTA
BLUE
WHITE
BLACK
BLACK
I'm guessing this is what you were looking for, hopefully it helps.
Old Mar 5, 2010 | 09:14 AM
Wow, that didn't turn out how it looked in my preview screen. I'll try and redo it again.
Old Mar 5, 2010 | 09:16 AM
Better yet, I'll just give you the URL that I got the universal diagram from.
http://stores.ebay.com/GLOBAL-AUTOMO...G-DIAGRAM.html
meltdowndave
Oct 12, 2017 12:27 PM
discobob
Nov 21, 2010 05:12 PM
whatmeworry?
Aug 1, 2009 08:23 AM
rj95lss
Jun 19, 2009 09:11 AM
maddisco
Feb 10, 2009 11:43 AM
