Another blown headgasket story
Old Feb 28, 2024 | 11:27 AM
Richard Gallant's Avatar
@treicruz Generally you want to avoid stop leak of any sort. It almost always creates more problems that is solves, also unless your head gasket leak is at the cooling jacket it will do nothing.
Old Feb 28, 2024 | 12:04 PM
treicruz's Avatar
@Richard Gallant understood, I just thought maybe you had done it per your first comment. I’ll look into it for now thanks. And yes motivation and time are the only factors holding me back haha
edit: sorry I addressed John’s comment.
Old Feb 28, 2024 | 12:36 PM
Harvlr's Avatar
John is probably right that the tablets will stop your leak, but I agree with Richard, in the longer run they’ll cause you more trouble than they’re worth.
Old Feb 28, 2024 | 05:16 PM
@treicruz I fit helps I did mine after work and on weekends in January under a tarp in my driveway, the was snow involved. At that point I had not head gaskets in 40 years so there is that
Old Feb 28, 2024 | 05:24 PM
Extinct's Avatar
Those halogen lamps throw off a lot of heat!!
Old Feb 28, 2024 | 06:00 PM
Greg_M's Avatar
Yeah, headgaskets never go when it's convenient/good weather.
Old Feb 28, 2024 | 11:40 PM
JohnZo's Avatar
About the tablets, they are sort of a last resort. I know my vehicle's cooling system is very clean an can handle them. They worked to dry up some annoying seepage from radiator end bell gaskets (aftermarket aluminum with plastic ends). Not sure how they would perform on a pressurized system.
One pack of six from an auto parts box store. I dissolved and mashed them up, siphon to free up some volume in the radiator to install, then run the engine to open the T-stat. A lot of the mass ended up in the coolant recovery tank, so I stir it up once in a while. I understand they were installed in GM vehicles at factory at some point in the past. A little bottle of K-seal was also an option, but I wanted to test the tablets and they worked great. The bits are small enough to not block radiator or heater cores. Cost less than $10. Probably problems with clogging is a risk if too much solid material is added to the cooling system, so only add a little to solve little leaks.
austinlandroverbill
Jun 23, 2014 02:01 PM
NickDisco99
Oct 24, 2012 02:17 PM
Mountain Goat
Jan 4, 2012 08:25 PM
scooter22
Dec 16, 2010 06:31 AM
j.dstasio
Apr 20, 2010 10:11 AM
