another code
Old Mar 23, 2010 | 09:21 PM
bt-dub's Avatar
Default another code
Just bought my first disco yesterday. So far im pretty happy. The only issue im having at the moment is my " Service engine soon" light came on about an hour after I bought it. Pretty aggrivating. The code reader says "P1415, Secondary air system fault bank 2drive cycle D: signal implausable". Any help would be great. Its a 2000. And I plan on doing the service work listed in the sticky. I would like to solve this issue first tho
Old Mar 24, 2010 | 12:17 PM
bt-dub's Avatar
Anyone? I really didnt want to take it to the shop right away
Old Mar 24, 2010 | 12:42 PM
okdiscoguy's Avatar
Check your hoses to the SAI pump.
Search works well on here...
https://landroverforums.com/forum/sh...ad.php?t=23113
Old Mar 24, 2010 | 02:51 PM
If you are not mechanical and are not familiar with the SAI system, find a good local Rover shop, not the dealer and have them deal with it, should be pretty easy fix.
Old Mar 25, 2010 | 02:46 PM
bt-dub's Avatar
thanks guys. I listened and felt the pump today and it seems to be running. I also checked the main hose to the pump with the heat wrap and it also seemed ok. Is there anything else i should check before having it looked at? THanks again
caymandrew
May 2, 2013 06:25 PM
lebrult
Jan 24, 2012 12:41 PM
sayeedA
Nov 15, 2011 11:02 PM
Hyakku
Sep 17, 2010 08:49 PM
JAC
Oct 2, 2009 09:41 AM
