Another Cooling Annoyance
So I have just been having a small drip coming from the radiator end cap/return line for the coolant tank. I pressure tested the system with no luck. Replaced the factory clamps. So today I went to lowes for supplies and come back to a drip of coolant. Tired of this stumping me I pull the upper shroud back off and find a pin hole leak in the radiator end cap.
Below is a video of the leak in question.
on
Good luck!!
sounds like the classic wrong screw (too long,) or not using a washer, in the shroud poked a hole in the plastic end cap.
Known stupid issue.
I temp fixed mine with RTV down the hole and the correct screw in on top. no issues since, though not a permanent fix it will get you by till you get a new rad.
I've been getting by for a year now on that fix, but ultimately a new rad is the fix, and not putting the wrong screw in there again.
Known stupid issue.
