Another Crank position sensor thread
Old Aug 25, 2014 | 12:08 AM
kfx4001442's Avatar
Also make sure that the sensor is in stalled correctly...It goes senor to block then spacers on the sensor then the nuts!
Old Aug 25, 2014 | 04:53 PM
vette427sbc's Avatar
Just checked for exhaust leaks... None. Felt the sensor properly "click" into connector, and installed correctly.
I made it half-way home yesterday then towed it the rest. Let it sit over night and it made the 15 minute drive back to my shop the next day. No CEL, or other issues. Today started up fine, although I havent driven it anywhere. Its currently running in the parking lot to see it I can get it to shut off and check if I can get an RPM signal under cranking. Otherwise Ill be checking for voltage out of the fuse box for the fuel pump.
Ultragauge seems to get an RPM reading no problem and it doesnt jump around like its getting a broken or intermittent signal.
Old Aug 25, 2014 | 05:11 PM
Update: Got the truck to shut down... It sat idling no problem, drove it around in the backyard for 2 minutes and it shut off mid-drive. Went to crank it and got no RPM signal. Safe to say its something with the CPS but what do I check now? Try another sensor?
Old Aug 25, 2014 | 05:17 PM
jafir's Avatar
Maybe. Where did you get the sensor? I assume a place like autozone would swap it out under warranty.
Also the fuse box issue I was talking about mimics the cranks sensor problem, but I don't think it's usually heat related. It's usually just no spark, even after replacing the sensor.
Old Aug 26, 2014 | 08:27 AM
I assume the potential fuse box issue is related to the fuel pump? So if it was a fuse box issue, I would still show RPM during cranking (which I do not)
Going to swap the sensor again today.
Old Aug 26, 2014 | 08:46 AM
jafir's Avatar
No, it was no spark.
Old Aug 26, 2014 | 11:05 AM
kfx4001442's Avatar
I would try squeezing that CPS connector together while someone else cranks the truck and see if you immediatly get that OBDII RPM reading and successful engine start when doing so. My problem was that I had not got that plugged up completely and was doing this EXACT thing after I did replaced my CPS twice! Just a thought...
Old Aug 29, 2014 | 02:15 PM
Ok... so what was the issue with the fuse box? Im still getting no RPM reading from my OBD port if that can prove or rule out the fusebox.
I also unplugged and re-checked checked the connection on the CPS.
Old Sep 4, 2014 | 07:12 PM
To update this thread, I swapped out my new Bosch sensor for another one (not Bosch) from advance auto. 2 days so far so good...
Old Sep 4, 2014 | 10:05 PM
dr. mordo's Avatar
Hmm... I'll be curious to see what happens.
