Another Disco II stuck in park
Old Feb 18, 2016 | 06:41 PM
  #21
number9's Avatar
Originally Posted by KeizerRover
Oof. Those XYZ switches are not exactly inexpensive. Is there a test procedure one can do on them to see if that is the culprit?
Recently changed mine with a used switch for a S&M issue. In retrospect wish I'd simply tried rotating prior to replacement.
For your situation simple check may be as suggested loosen bolts & rotate. If that doesn't work remove and rotate through travel several times and try it again. Contacts inside get dirty.
One check is what you already did, faulty indication of gear selection.
Old Feb 18, 2016 | 06:58 PM
  #22
KeizerRover's Avatar
I'll tackle that tomorrow and report back. Thanks!
Old Feb 18, 2016 | 08:55 PM
  #23
mln01's Avatar
Can we please refer to the transmission fault indicators as M&S lights and not an S&M issue?
Old Feb 18, 2016 | 09:53 PM
  #24
number9's Avatar
Probably not unless many consider it offensive.
From D2 Workshop Manual:
'Sport' and 'manual' lights flash alternately.
Economy, sport and manual modes
Limp home mode is selected and vehicle performance is greatly reduced. The sport and manual warning lamps flash.
Sport/Manual warning lamp circuit fault
Old Feb 19, 2016 | 03:38 PM
  #25
mln01's Avatar
I was trying only to inject a little humor.
Old Feb 19, 2016 | 03:53 PM
  #26
number9's Avatar
Worked and glad to know you're not S&M or dyslexia phobic.
Old Feb 22, 2016 | 04:47 PM
  #27
How do you get the electrical connection apart without using a hammer and/or wire cutters?
Old Feb 22, 2016 | 05:23 PM
  #28
drowssap's Avatar
Squeeze the connector while pulling the plug, they lock together.
Old Feb 22, 2016 | 05:29 PM
  #29
mln01's Avatar
Which connector?
Old Feb 22, 2016 | 05:33 PM
  #30
Which connector?
The wire connection for the "XYZ" switch on the transmission.
**edit**
Also, is there a way to test this switch at all to see if it is indeed dead before I spend the money on a replacement?
