another leaking upper radiator hose T
Old May 1, 2016 | 05:25 PM
mln01's Avatar
On my last trip to the boneyard I picked up two upper hose T's as spares.
Old May 2, 2016 | 10:16 AM
T-rex's Avatar
Here's a quick photo
T fitting fix
The head of the bolt - on the inside, has a rubber washer. I cut the slit in the top of the bolt so I could keep it from turning when tightening the butterfly bolt.
Old May 2, 2016 | 12:35 PM
Charlie_V's Avatar
T fitting fix
Nice solution!
Old May 4, 2016 | 06:57 AM
RawFaith's Avatar
T fitting fix
pretty neat!
went to lowes and got the T.... but no bleeder . not sure about the cons of no bleeder?
Old May 4, 2016 | 06:58 AM
RawFaith's Avatar
"made a small flare"
Old May 4, 2016 | 06:59 AM
RawFaith's Avatar
and a temporary solution since it was Sunday !
Old May 4, 2016 | 08:41 AM
Charlie_V's Avatar
I like that alot.
The only con of no bleeder is getting air out when you change the coolant, or if you wanted to put a sensor in the bleeder thread. But the air will work its way to the expansion tank and, honestly, how often do we have to change the coolant...
DonRW2007
Jul 2, 2015 12:16 PM
Selvol
Nov 12, 2012 05:18 AM
