another question
Old Dec 16, 2009 | 10:54 PM
JumPeR04's Avatar
Default another question
Hey since I change the steer pump,alternate ,and the main belt. My rpm and temp gauge is not working right like on rpm gauge 70 mph is at 2000 and idle is beyond 1000 then temp gauge is not in the middle after I let it warm up
Old Dec 16, 2009 | 11:44 PM
Bob2003Discovery's Avatar
Are you certain you have the correct alternator and it is wired up correctly? Sounds like an electrical issue...
Old Dec 17, 2009 | 12:14 AM
JumPeR04's Avatar
It came off a 95 or 96 but they junkyard told me it whould work since the one they sold had a broke connect that was a 97 so they chould have gave me the wrong one if that is the case will be ok to run for awhile inthen I get another one
Old Dec 17, 2009 | 02:00 AM
LRScott's Avatar
NO! you run the risk of frying all sorts of expensive electronics. Make sure it is supplying the correct amount of electricity. Rovers do strange things when they don't get the proper amount.
Old Dec 17, 2009 | 08:26 AM
JumPeR04's Avatar
Ok does anyone know where I can trade this one for the right one if not I will try get another alternator from that junkyard
caymandrew
May 2, 2013 06:25 PM
Hyakku
Sep 17, 2010 08:49 PM
JAC
Oct 2, 2009 09:41 AM
russ00001
Mar 30, 2006 09:47 PM
Benhamtroll
Nov 18, 2005 03:49 PM
