Another Rear Door Problem
Old Aug 4, 2009 | 09:05 PM
Shadley's Avatar
Default Another Rear Door Problem
Just got my 2004 disco home and the rear door handle will not budge. Its in the position it should be in but just will not move. I opened it at the dealer. Should I take off the emblem and if I do will the emblem pop back on? Thanks!
Old Aug 5, 2009 | 09:05 AM
Take of the emblym and wash the handle system with some high pressure water, that usually will fix it.
Old Aug 5, 2009 | 05:27 PM
Dont use water as that will make the handle and spring rust, use silicon spray lube, $3 at Wal-Mart.
There is a thread about this already.
https://landroverforums.com/forum/sh...ad.php?t=23948
Old Aug 6, 2009 | 08:06 AM
Shadley's Avatar
Default Thanks Guys
Got it unstuck. I think someone just shut the door very easy and it was stuck between shut and not shut. I'll be back with more questions. Thanks Shadley
Old Aug 6, 2009 | 08:11 AM
lipadj46's Avatar
It will continue to get worse and eventually you will not be able to open your gate so make sure you still go in there and lube it.
jigray3
Jul 30, 2019 07:52 PM
caymandrew
May 2, 2013 06:25 PM
Hyakku
Sep 17, 2010 08:49 PM
JAC
Oct 2, 2009 09:41 AM
