Another Slow Speed Noise
Old Feb 12, 2022 | 06:14 PM
cvhyatt's Avatar
Default Another Slow Speed Noise
Trying to get all the loose ends tied up before I head out on the 5000 mile trek out west.
And of course, a mysterious clatter shows up.
It is in the rear. I fixed a loose heat shield, tightened the rear shocks and checked other suspension parts for worn bushings or looseness but haven’t found anything of note.
Only seems to happen when I hit a bump or a hole on one side at very low speed. Any thoughts on what else to check?
Old Feb 13, 2022 | 01:31 PM
cvhyatt's Avatar
Just to close this one out. It was the front driver side sway bar link that was loose on the bottom. Retorqued it to 74flbs and no more sound. I spent all my time earlier investigating the rear because that's where it sounded like it was coming from. I found it by having my son push on the rear bumper passenger corner while I crawled underneath with the creeper.
Lesson #325: Until you get under the truck, you are just guessing.
Quickserv
Range Rover L405 (Fourth Gen)
17
Oct 12, 2025 11:32 PM
tsb
Aug 14, 2021 01:49 AM
TRIARII
Mar 31, 2014 02:43 PM
mrjlyr
Jan 16, 2010 04:00 PM
Aquaholic
Apr 8, 2007 11:55 AM
