Creaky noises coming from rear end after long drive
Old Mar 28, 2014 | 01:12 AM
TRIARII's Avatar
Default Creaky noises coming from rear end after long drive
Ive noticed a creaking noise coming from outside the vehicle at the rear end of my Disco. Sounds like it may be the coils or shocks? Dont hear it when I get in the truck but after 20 minutes of driving to and from work once I turn the truck off the creaky noises kick in. Is this normal? Do springs/shocks make any type of creaking noises like this? You can make replicate the noise my moving around in the truck. Recently installed a new TF 2" suspension lift so I dont expect any of the kit would be failing on me. Have not noticed any saging on either side of the truck either. Thoughts?
Old Mar 28, 2014 | 02:01 AM
zeroone's Avatar
May sound stupid.. dry bushings maybe? Possibly the old bushings that you may not have replaced?
Old Mar 28, 2014 | 03:16 AM
TRIARII's Avatar
I have not replaced any bushings yet. Hoping to wait a little longer (Spring before I tackle bushings). The creaking sounds metal like though.
Old Mar 28, 2014 | 06:01 AM
drowssap's Avatar
are the springs seated in the saddles
Old Mar 28, 2014 | 12:36 PM
Dane!'s Avatar
My truck creaks when its cold, its normal. Check your watts bushing.
Old Mar 28, 2014 | 12:53 PM
TRIARII's Avatar
Im not exactly sure where all the bushings are located. All I know is it sounds like its coming from where the coils are. Yes the coils are installed in the seats properly.
Old Mar 28, 2014 | 01:19 PM
jamestfl's Avatar
I get creaking going over speed bumps, but my shocks are shot. have also wondered if it's bushings.
Old Mar 28, 2014 | 02:43 PM
zeroone's Avatar
You can always shoot them with some spray lubricant. If they are shot that may shut them up for a bit. Mine have been quiet for 2000 miles. But they aren't exactly shot either. Just dry.
Old Mar 31, 2014 | 10:27 AM
drowssap's Avatar
did you move the rubber spring isolators over from the old coils?
Old Mar 31, 2014 | 02:43 PM
dusty1's Avatar
x2 on isolators. no way it is exhaust pipe cooling off? it is right there at the ds rear coil as it does its funky s shape to get to the bumper area.
DiscoJon
Jul 14, 2019 01:51 PM
leamas57
Freelander
Jan 16, 2014 04:03 PM
leamas57
Freelander
Nov 1, 2013 04:20 PM
audiS4S6
Apr 18, 2010 11:02 PM
freelanderjames
Freelander
Dec 24, 2008 10:18 PM
