Another tire post.
Old 09-11-2020 | 07:00 PM
xhevi's Avatar
Default Another tire post.
First of all, I hope everyone and their loved ones are as healthy as they were last Christmas and even better.
I have not been on here in quite some time.
Have had my 245/74/16 duratrack for about 6 years and have about 60 000 miles on them.
They are overdue for a change since 10k miles ago. Severely cupped due to warn out shocks.
Had the HD OME shocks and springs installed about 8 years ago. Few months back I installed the terrafirma shocks and kept the OME shocks. Rides smoother other then the noise and shaking from the bad tires.
I ordered Cooper Discoverer A/T all season 111T 245/75/16 from Walmart And they arrived in mail today.
​​​​The side wall felt soft as I was stacking them up so I looked on the sidewall and found its a 2 ply sidewall.
Anyone runs these? I think 2 ply would be extremely soft. Right?
Old 09-11-2020 | 09:43 PM
xhevi's Avatar
Seems like they both have similar construction
Goodyear Wrangler Duratrac LT M+S
Thread: 2 ply polyester +2 ply steel
Sidewall: 2 ply polyester
Copper Discoverer A/T 111T
​​​Thread: 1 ply nylon +2 ply polyester +2 ply steel
Just a fun fact, my motorcycle tires have 2 ply nylon thread and sidewall.
Old 09-12-2020 | 01:06 PM
whowa004's Avatar
Should be fine for normal road use. I know lots of people who won't run duratracs off road due to weak sidewalls (I had a set and just wasn't impressed with their grip and quickly moved on from them) and they had plenty of documented failures. I think you will enjoy the coopers much more and will be just fine.
Old 09-12-2020 | 01:58 PM
Discorama's Avatar
What is the max cold pressure stamped on the tire?
Old 09-16-2020 | 07:28 PM
xhevi's Avatar
Says Max pressure 44 psi. I would assume it's cold.
So I got them mounted and I am in love again. Was hating the ride and was considering to end a 10 year relationship with the disco.
Other then how quiet they are i don't have much else to comment on the tires as it's only been a week.
​​​​However any other tire would have been much better then the Fred Flinstone tires I had on. The cupping was so bad that at very low speed I would notice the hood move left, right, up, down like a boat.
Next I got to replace leaking throttle body heater, Wich seems like I have to replace every couple of years.
Cheers
Old 09-16-2020 | 09:08 PM
Bignacio's Avatar
I use the Duratrac's with a E load rating. I believe the sidewalls are stronger and more geared toward our D2's
Old 09-16-2020 | 11:14 PM
Discorama's Avatar
It is always cold pressure. The recommended pressure for the rear under max load conditions is 46 psi. I am using that on my camping trips. It would be over the limit with 44 psi tires. I decided for 50 psi tires.
KingKoopa
06-28-2017 11:08 PM
El Duce
10-22-2016 05:18 PM
olywa
11-21-2013 06:42 AM
bantham1
03-26-2010 03:12 PM
sayre05
03-25-2008 09:40 AM
Quick Reply: Another tire post.
