Antifreeze leak?
Old Jun 9, 2015 | 10:39 AM
ServerGuy's Avatar
4th Gear
Default Antifreeze leak?
I believe im leaking antifreeze somewhere. From below i noticed some antifreeze colored drips (see pictures below) but not sure what would be causing it to become thick and stick on the underside. Based off the picture does anyone have some advice of what might be causing this?
https://drive.google.com/file/d/0Bw3...ew?usp=sharing
Old Jun 9, 2015 | 10:57 AM
drowssap's Avatar
you need to pressure test your system, but i would say the weep hole on the water pump is leaking, maybe someone put stop leak in it?
Old Jun 9, 2015 | 01:05 PM
jamestfl's Avatar
good pics. x2 on the weep hole.
Old Jun 9, 2015 | 01:52 PM
ServerGuy's Avatar
4th Gear
Thanks, If I find it is weep hole, what is the best solution for this?
Old Jun 9, 2015 | 02:36 PM
drowssap's Avatar
Replace the water pump is the only option. Might want to replace the hoses, belt and install a TD5 thermostat if they havent been replaced makes no sence to "me" to put 10+ year old stuff back on.
Old Jun 9, 2015 | 03:31 PM
ledbetter_11's Avatar
5th Gear
having same problem but mine is at the bleeder screw have you guys had this same issue and what did you do to fix I would like to go to brass plug but looking for other options
Old Jun 9, 2015 | 03:34 PM
drowssap's Avatar
Brass BMW screw is it
Old Jun 9, 2015 | 04:59 PM
jfall's Avatar
Replace the Water Pump.
you could have the bearing freeze up, smoke off the belt and then you over heat out on the road.
Then your engine is done.
So, man up.
Water pump time.
Old Jun 9, 2015 | 10:13 PM
5th Gear
yes maybe what year did the bmw use the tee fitting and where can I find one
BigBee79
Nov 9, 2010 02:30 PM
princevince
Freelander
Apr 14, 2010 08:28 PM
theresa
Nov 26, 2008 09:00 AM
03WhiteDisco
Nov 20, 2008 01:57 PM
nydiscovery
Jan 27, 2006 11:16 AM
