Any hard in an injector cleaner?
good thing to do, actually. I throw a can of BG44K in every 10K.
Have you ever changed your plugs and wires? Magnacor 8MM and some Bosch +4's will help.
Check the sticky's at the top for the service and get started on it if it has not been done. It is the 60K service and you are there....
I've use SeaFoam in my Ford Bronco II and just picked up some more today for the Disco. It will remove carbon deposits from the top of the pistons and valves as well as clean your injectors. After using it in my Bronco, I got an additional 40 miles out of a tank of gas. I'm guessing it helped.
Tony Back
08-21-2014 11:37 PM
DeepBlueWater
10-15-2007 07:38 PM
