Any hard in an injector cleaner?
Old Feb 24, 2010 | 10:19 AM
neroverguy's Avatar
Default Any hard in an injector cleaner?
My 99 Disco 2 has 59k on it. It seems a little sluggish, any benefit/harm using an injector cleaner?
Old Feb 24, 2010 | 10:26 AM
okdiscoguy's Avatar
good thing to do, actually. I throw a can of BG44K in every 10K.
Have you ever changed your plugs and wires? Magnacor 8MM and some Bosch +4's will help.
Check the sticky's at the top for the service and get started on it if it has not been done. It is the 60K service and you are there....
Old Feb 24, 2010 | 02:00 PM
neroverguy's Avatar
Default Thanks!
Will look into it, Throttle body cleaner recommended?
Old Feb 24, 2010 | 02:27 PM
yloDiscoII's Avatar
I think most use carb cleaner spray and a wire brush to clean out the throttle body. I put some Lucas UCL in every tank and use Lubra Moly injector cleaner each oil change.
Are you running premium gas?
Old Feb 24, 2010 | 02:37 PM
lipadj46's Avatar
Use a cleaner that has polyether amine (PEA) such as techron or redline or amsoil. PEA is the only proven cleaner that will actually be effective at the concentrations we use it in. With all the ethanol in gas these days though dirty injectors are usually not an issue.
Old Feb 24, 2010 | 03:36 PM
neroverguy's Avatar
Default I just got it
I just got the truck, I am not sure what they ran it it before. It looks to have plug wires and plugs replaced. It has had synthetic oil its whole life i am told.
Old Feb 24, 2010 | 03:45 PM
okdiscoguy's Avatar
The major service list is something to do whatever your mileage when you get a new truck. Things can "look" good but be bad. This also gives you a good baseline for keeping your service up.
Anything written on the wires?
Old Feb 24, 2010 | 06:02 PM
I agree that as long as you use good gas a injector cleaner is not needed, it wont hurt, but its not needed.
That being said, since you do not know the true history of the truck yes go ahead and use injector cleaner.
Yes clean your throttle body, once a year.
Old Feb 24, 2010 | 09:03 PM
geoffthepoolguy's Avatar
I've use SeaFoam in my Ford Bronco II and just picked up some more today for the Disco. It will remove carbon deposits from the top of the pistons and valves as well as clean your injectors. After using it in my Bronco, I got an additional 40 miles out of a tank of gas. I'm guessing it helped.
Tony Back
Aug 21, 2014 11:37 PM
tshirttom
Dec 2, 2009 11:13 PM
targotsi
Jan 31, 2009 06:12 PM
DeepBlueWater
Oct 15, 2007 07:38 PM
