Any trick to the steering knuckle?
Old Apr 14, 2025 | 08:57 AM
DiscoOslo's Avatar
Default Any trick to the steering knuckle?
I'm trying to do the front ball joints. I am working on the front driver's side first. I am down to taking the knuckle off, but I cannot get it to budge. I have followed the RAVE manual, but I am using a "pickle fork" as I have heard it called, and not the exact tool listed in the RAVE. I cannot get it to budge off the ball joints. Maybe of note, but the bottom ball joint seems to twist when I move the knuckle, I can see the threads moving. The top doesn't do that. I've been hammering at it (1/2 kg sledge) on the fork for maybe 1.5 hours now. I've soaked it before in penetrating oil, but I have it soaking again. Any tips to get that damn thing off?
Old Apr 14, 2025 | 09:51 AM
Brandon318's Avatar
This is one of the more frustrating disco projects, sorry it’s giving you grief. So I’ve found the most success by giving it a blow with a sledge on that top flat spot.
I’ve started with a dead blow mallet, then escalated to a 3lb, and then finally knocked it off with a 5-er.
Old Apr 14, 2025 | 09:55 AM
DiscoOslo's Avatar
Yea. After some reading, I think I am going to need a bigger sledge. I started with a dead blow, then a ball-pin hammer, now a small sledge. I've also seen its supposed to be hit right by the taper joint, but so far that has done nothing. Sounds like I am off to the store again...
Old Apr 14, 2025 | 12:50 PM
JohnZo's Avatar
Sorry for the struggles. Land Rovers are good reasons to buy good tools. I like to back the section up with one heavy hammer, then whack it on the opposite side. Theory is to cause a slight deformation that allows the taper to drop out. Maybe also use a clamp-style remover to create some tension prior to hammering. Some heat might also help, for a bit of expansion. Once the technique is perfected, it takes only minutes. Check out online videos. Note the tapers fit so closely that penetrating oil does not penetrate.
Old Apr 14, 2025 | 01:03 PM
DiscoOslo's Avatar
Interesting about the oil. Should have figured that. I sold a lot of my tools when moving from the US to here, slowly reacquiring. My 15 lbs maul would have been handy today... Alas. I've gotten a larger, 6lbs sledge now I will try in the morning, then go suggestion by suggestion until it clears.
Old Apr 14, 2025 | 01:36 PM
Brandon318's Avatar
Probably the most precision engineered part on these things haha
Old Apr 16, 2025 | 10:21 AM
redrover75's Avatar
What about heat and wax? that may be just enough to get it loose? It always hard to tell what did loosened a fitting, but I seem to have had luck that a number of times. Could have been the penetrant or heat or anything else I used, but it seems to have helped.
Old Apr 16, 2025 | 10:32 AM
DiscoOslo's Avatar
I thought I posted, but I don't see it. I was able to procure a 2.7kg sledge hammer, and after about 5 minutes of hitting the taper joint it broke loose. Ball joints are replaced now. ☺️
Old Apr 16, 2025 | 10:35 AM
Brandon318's Avatar
Great feeling isn't it?
Old Apr 16, 2025 | 10:37 AM
DiscoOslo's Avatar
Totally! I'll tackle the other side this summer when I have some more time. The power steering pump is a little more pressing...
twr7cx
Dec 21, 2018 04:17 PM
me 2
Feb 26, 2016 06:30 PM
evansjoem
Nov 12, 2013 12:21 PM
hevkev
Jan 12, 2009 11:31 PM
Newbie
Nov 13, 2007 09:25 AM
