Any tricks to removing the fan without the special holding tool?
I used a long chisel, scared it off, never to go back on.
(2 - 12" electrics summit racing) close to rad, no shroud, (1) stat, (1) DTSP center off switch under dash, can disable fans if necessary.
I think (don't know) that the absence of the heavy poorly balanced clutch fan also helps the waterpump bearings.
luck,greg
luck,greg
I used a big screw driver and wedged it against the motor so the shaft of the screw driver locked against the bolts to stop it spinning. then just used a spanner to unscrew.
2 handed job but easy enough.
________
College Girls Cam
________
College Girls Cam
alpinab7
11-27-2006 07:34 PM
