any tricks for unbolting brake disc from hub assy???
Old Nov 11, 2006 | 04:22 PM
alpinab7's Avatar
Default any tricks for unbolting brake disc from hub assy???
I have soaked it for days with penetrant and am using an impact driver. Am I going to need to bring it to someone with a pneumatic impact gun? 93 LWB if it matters
Old Nov 27, 2006 | 01:55 AM
moneypit37's Avatar
Default RE: any tricks for unbolting brake disc from hub assy???
I had to do mine a while back and I think I ended up using my HI-Lift jack handle over a ratchet and probably thrashed the ratchet in the process.
Old Nov 27, 2006 | 07:34 PM
scubasteve's Avatar
I used the impact driver and it worked fine. Is the blade tip wide enough for the head of the bolt? I tried a couple of blade sizes and the widest one worked the best. I know what you're feeling....I was scared when I had all but one off...I was thinking of the worst.
Anyway, good luck. I guess you could drill the bolt out or even use a reverse thread screw extractor. Every garage should have a screw extractor set, they're priceless.
-Steve
Racer X
Oct 10, 2016 09:32 AM
cello
May 31, 2010 12:46 PM
audiS4S6
Apr 30, 2010 09:40 PM
sailorcolin
Oct 1, 2008 09:57 PM
98xc800
Sep 30, 2008 04:51 PM
