Any tricks to removing the fan without the special holding tool?
I need to get my radiator out tomorrow and am stuck (although I didn't try real hard - currently nursing a stomach bug).
TIA.
TIA.
I used a long chisel, scared it off, never to go back on.
(2 - 12" electrics summit racing) close to rad, no shroud, (1) stat, (1) DTSP center off switch under dash, can disable fans if necessary.
I think (don't know) that the absence of the heavy poorly balanced clutch fan also helps the waterpump bearings.
luck,greg
luck,greg
I used a big screw driver and wedged it against the motor so the shaft of the screw driver locked against the bolts to stop it spinning. then just used a spanner to unscrew.
2 handed job but easy enough.
________
College Girls Cam
________
College Girls Cam
lipadj46
Aug 27, 2010 09:06 PM
alpinab7
Nov 27, 2006 07:34 PM
