Anybody ever seen code P1450?
I wouldn't necessarily disagree with you,....but after having 4 prior Land Rovers that I had decided were junk,....I bought my current one two years ago for $850. It looked and drove well, had Cold A/C and newish tires, its a 2003. It did have the requisite sagging headliner, and the radiator was seeping a bit, and,....it had several DTC codes being displayed. I had to replace the intake gasket and Plug wires to get rid of the codes,.....no easy job and ridiculously expensive at the LR dealer,....but better than doing head gaskets which I had to do on my prior Disco. Once I got those things done and replaced the front brake rotors and pads, and rebuilt both driveshafts (was chasing a vibration,....this did not fix it),...and later replaced the E brake drum which fixed my vibration. The truck actually turned out to be a very reliable and solid truck and I think I had somewhere between $1500 and $2000 in it at that point. Fuel mileage is 12 mpg for general running around, and 15 on the highway if driven at posted limits. I just ordered a EGR Purge valve, hoping that will take care of my 1450.
What / Where is the DMTL pump? Haven't done a smoke test yet
Any other suggestions?
Evaporative emission system (with
positive pressure leak detection)
component layout (NAS only)
hilltoppersx
ROAMING WITH FRIENDS
Dec 13, 2009 08:49 AM
