Anybody ever use these ext. bump stops?
Hoping to find out what D2 owners are using for extended bump stops with 2" lift and +2 ext. travel shocks. I found this on the Internet from the UK, but seems a little pricey, even before shipping, but that may be the going rate for poly, I don't know. Let me know your thoughts or what you are using. THANKS
RNV100060PE | Polyurethane Bump Stop - Extended
Thanks for posting this...it reminded me that I need to replace my bump stops. When under the truck last week changing the motor mounts I noticed one is gone altogether (just the rubber part).
I stopped running poly bump stops after destroying a pair of them, and seeing a couple others gets destroyed on other rigs. They were the Energy Suspension ones though, not the ones posted above.
I went with some GM bumps pulled from the junkyard. Working very nice - tires (255/85s) don't make contact with the inside of the wheel well.
So, what else do I need to do to do it right?
CANAMDiscovery
Apr 2, 2012 04:20 PM
RROJ
Nov 20, 2010 01:21 PM
brandon4589
Jan 2, 2009 09:47 PM
