Anybody ever use these ext. bump stops?
Old Sep 4, 2012 | 11:39 PM
Rover_Hokie's Avatar
Default Anybody ever use these ext. bump stops?
Hoping to find out what D2 owners are using for extended bump stops with 2" lift and +2 ext. travel shocks. I found this on the Internet from the UK, but seems a little pricey, even before shipping, but that may be the going rate for poly, I don't know. Let me know your thoughts or what you are using. THANKS
RNV100060PE | Polyurethane Bump Stop - Extended
Old Sep 5, 2012 | 06:45 AM
drowssap's Avatar
thats because they are Polyurethane, any polyurethane bushing or bumper is twice the cost of rubber
Old Sep 5, 2012 | 08:01 AM
ZGPhoto's Avatar
I have them. Got them from RN, a little grinding of the soft metal to make fit.
Old Sep 5, 2012 | 08:03 AM
I have run a 3" lift for nearly 10 years and never had need to replace the bump stops.
Old Sep 5, 2012 | 08:55 AM
dcarr1971's Avatar
Thanks for posting this...it reminded me that I need to replace my bump stops. When under the truck last week changing the motor mounts I noticed one is gone altogether (just the rubber part).
Old Sep 5, 2012 | 06:48 PM
Banzai Jimmy's Avatar
I stopped running poly bump stops after destroying a pair of them, and seeing a couple others gets destroyed on other rigs. They were the Energy Suspension ones though, not the ones posted above.
I went with some GM bumps pulled from the junkyard. Working very nice - tires (255/85s) don't make contact with the inside of the wheel well.
Old Sep 5, 2012 | 07:54 PM
ebg18t's Avatar
just the stock bump stops here. no need for anything different.
Old Sep 6, 2012 | 09:11 AM
So I should not have any issues bottoming out the shocks? What about spring retainers, should I add them? top and/or bottom? Cones? Do you take sway bars off or disconnect for trail riding? I have heard stories of bottoming out extended shocks and springs coming unseated as well with a lift, and since this is my first lift, I just wanted to do what is needed to do prevent those issues?
So, what else do I need to do to do it right?
CANAMDiscovery
Apr 2, 2012 04:20 PM
RROJ
Nov 20, 2010 01:21 PM
raid13
Apr 16, 2009 09:33 AM
roverfun
Jan 3, 2009 04:35 PM
brandon4589
Jan 2, 2009 09:47 PM
