Anybody smoking in North Jersey? ~ P0441
Old Apr 3, 2014 | 07:57 AM
teeboli's Avatar
Default Anybody smoking in North Jersey? ~ P0441
Anybody out there in North Jersey (north of rt. 80) with one of these Smoke generators/testers that can help me route out the source of my P0441 (Purge Flow) code? I have replaced the cap with an OEM and put in an OEM Purge Valve and the bloody code keeps popping up every couple of fill ups. I don't want to put this in the hands of the dealer to fix for obvious reasons. Thanks
Old Apr 3, 2014 | 08:59 AM
jfall's Avatar
Here is an example of smoke generation which you can do yourself
Old Apr 3, 2014 | 09:42 AM
teeboli's Avatar
thanks I needed that! If I lived in CO trust me I would be out there trying that with a tube going into that diag port..
Old Apr 3, 2014 | 12:56 PM
primussucks's Avatar
I fought P0441 for a LONG time... I disregarded my Purge valve because I had recently replaced it. I smoke tested, pulled my hair out, nothing worked... Last ditch effort I replaced the purge valve again... it worked... as soon as I hooked it up, it started clicking away (purging)... I would recommend getting another purge valve (and making sure you are connecting to the right connector, and not the 2nd Air valve)... I use the Dorman purge valve... about $20 from NAPA or Amazon. HTH
Old Apr 3, 2014 | 01:04 PM
Dane!'s Avatar
The Dorman one sucks!
If your going to buy the Hyundai one go to the Hyundai dealership and get the OEM one. The Dorman (aftermarket Hyundai part) can't handle the heat of the Land Rover's engine bay and they become brittle and crack. They also click as soon as you put them in like primmus said. I put one in my brothers and we returned it the same day and put the Hyundai one from the dealership in there and all is well now. I bought it for 60$, which I'm not sure is too much cheaper than the LR OEM one.
Dane.
Old Apr 3, 2014 | 01:05 PM
Dane.
Clicking = I know its working
Dripping Oil = I know its not empty
Old Apr 3, 2014 | 10:54 PM
teeboli's Avatar
Thanks!. I bought a OEM LR valve which is why I am expecting the thing to actually work. I will buy another one (not sure which yet) and give it a go and listen for clicking which I have never actually heard.
Old May 16, 2014 | 02:07 PM
teeboli's Avatar
UPDATE: The OEM Hyundai Purge Valve purchased via Amazon fixed the P0441 problem. Go figure that the $100 OEM LR purge valve did not work.. Thanks for the tip to RE-Replace the valve guys!
Nate Figueroa
Jan 8, 2013 02:20 AM
DV57
Mar 2, 2012 06:03 PM
Antmen
Apr 10, 2010 03:45 PM
Nitro96
Jan 5, 2008 10:45 AM
GadgetRick
Jun 24, 2005 03:12 PM
