Anybody use Synthetic oil?
Old Apr 6, 2006 | 05:12 PM
GA ROVER's Avatar
7th Gear
Default Anybody use Synthetic oil?
I am thinking of using either Mobil1 or Amsoil 5w-40. Any comments?
Old Apr 6, 2006 | 11:34 PM
Landzu's Avatar
Default RE: Anybody use Synthetic oil?
I use the Mobil 5W40 truck & Suv but not for summer.
For summer I use the what is now called Mobil One Extended Performance 10W40.
They say it good for 15,000 miles I go 5,000.
On the old style motor that we have you can get a lot of build up on the
inside and oiling was not a high point for this V8.
You could do with less if you only keep a vehicle for a few years.
Old Apr 7, 2006 | 07:41 AM
irishrover110's Avatar
Synthetic oil. YES it is the only way to go. I use it in every thing I own. I use it in anything that has moving parts and I change it often. Synthetic oil is not susposed to brake down like other oils, but I am sure it gets just as dirty. I am not sure if it matters much which one you use. Synthetic is the only way to go if you care about your toys.
Regards Dennis
Old Apr 7, 2006 | 10:55 AM
GA ROVER's Avatar
7th Gear
Thanks I appreciate the responses. I went to get some Power steering fluid yesterday cause i was sitting on the minimum reading with the truck off. In the manual it said there would be 2-caps mine only has 1 but it is a huge canister so I assume it is for the ACE[&:] Also it said to use Texaco PAS(Power Assist) I guess...and it should be amber in color. We looked for the cross ref @ Auto Zone and no cross ref for that or the GM one mentioned....Does it really matter?
Old Apr 7, 2006 | 11:37 PM
Bait's Avatar
Syn in the older AL V-8's is a waste of money. Syn in the newer BMW and Jag engines is worth it.
Old Apr 8, 2006 | 12:40 AM
05LandRover's Avatar
Mobil 1 0W-40 in both land rovers. 2005 Freedlander and 2005 LR3
Old Apr 8, 2006 | 04:59 PM
GA ROVER's Avatar
7th Gear
Mine is a 99 Disco II and has 56,000 mls. on it. Any help on the Power Steering/ACE fluid?
Old Apr 9, 2006 | 11:56 AM
disco01DS's Avatar
3rd Gear
I use Castrol Syntec 5W50. I still stick to the 3000mi 3month oil change schedule. Syntec was recommended to me early on and is really the only thing I've used.
Old Apr 10, 2006 | 10:24 AM
Landzu's Avatar
I'm not sure on the power steering fluid the dealer may be
your best bet. The Disco I uses Dex-ATF for the power steering.
I have a VW and nothing is normal on it, dealer fluid on
power steering.
Old Apr 12, 2006 | 03:36 AM
ghazz's Avatar
I just use dealer recommended, never had a problem, great efficiency.
