Anyone have experience with the tf 3” heavy duty lift?
Old Dec 6, 2017 | 03:17 PM
Fastercat's Avatar
Default Anyone have experience with the tf 3” heavy duty lift?
I will be installing this lift hopefully in the next few days, I also will install a tom woods front driveshaft. Eventually I will make bumpers and install a winch. Any idea the max tire size on a 16” rim I could get away with?
is there any other things I should address for drivability and or flex? I see all kinds of accessories like the spring cones, extended sway bar links, brake lines ect.
Old Dec 6, 2017 | 03:51 PM
Alex_M's Avatar
I'm on 3.5", but it's sagged a hair so really 3. I'm sitting on 285/75r16s and they're the perfect size IMO. Stock gears are a little sluggish, but plenty drivable. I even tow quite often and quite a bit of weight. I'll eventually go to 4.12 gears, but not in a huge rush unless the front diff I semi-broke really let's loose.
Old Dec 6, 2017 | 05:24 PM
I'd give a 2nd on the 285/75 unless you can find 255/85 to me they just look perfect on a lifted Rover
Old Dec 7, 2017 | 10:25 PM
Fastercat's Avatar
thanks guys. I’ll probably go the 285 75 if I go all terrains. If I go muds it’ll be the 255 85. I too like the skinny tire look as long as there mud tires.
Lift kit and off road goodies showed up today 🙂
Old Dec 8, 2017 | 08:13 AM
Best4x4's Avatar
I've installed and used the TF 3inch lift before. I had great results with the ride quality and it lifted my D2 evenly. A few pointers though..... Before installing them spray the coil springs down with some clear coat, it'll keep the paint from just blowing off in the wind. Also I had issues with the diameter of the rear HD 3inch springs fitting around the coil spring isolator pads. I had to press them in or they'll end up not sitting inside the coil spring causing the lift to be uneven.
Besides that I have no complaints. I like the ride quality of the TF shocks as well.
Old Dec 10, 2017 | 06:05 AM
Fastercat's Avatar
The lift is in, along with new brakes, needs some new rubber 😁
Old Dec 10, 2017 | 06:02 PM
Looks like a great day in the shop to me
Old Dec 11, 2017 | 04:18 PM
Spam2021's Avatar
hey Fastercat, did you take a measurement before and after the lift for actual lift?
Old Dec 11, 2017 | 04:54 PM
The Deputy's Avatar
Looks great. Where are you located in Canada?
Brian.
disco2life
Oct 18, 2019 04:54 AM
Twaszak1
May 12, 2017 01:08 PM
Blakesrover
Feb 20, 2013 10:31 PM
calebbo
Nov 9, 2011 11:31 AM
Aj6543
Sep 21, 2009 11:17 AM
