Anyone have a Nanocom in Denver?
Hey folks, my P38 has stopped turning over and I just replaced the starter motor. But it's still not turning. Does anyone have a Nanocom - I have a feeling the immobilizer has kicked in and the ECU needs to sync with the BeCM.
Would really appreciate the help - this pain the *** beauty is my daily driver!
https://www.google.ca/search?q=p38+e...0PEP1LmEiAU_24
If you’re immobilized due to improper locking sequence (and you don’t have a working fob), you may need to try the EKA (emergency key access) code. The fellow on the above video is in the UK and his EKA is different, but the procedure is the same. The EKA on our NAS vehicles is often 1515, so you could try that.
Is the EKA code the same as what’s in the manual? I’ve used a 4 digit code to unlock my radio before - wondering if it’s the same as that…
Check engine light popped up soon after. I didn’t pay much attention to it since the call was tuning over okay with the new battery.
Then I started to feel a kinda misfire - was struggling to get power when accelerating. Then kaput - stopped turning over entirely.
Toed it to the local shop to get the starter motor replaced but still not luck. Just need it to turn over so that I can check combustion and fuel pump (assuming the starter motor wasn’t the issue)…
