Anyone just give up on cracked bumpers?
Old Mar 10, 2014 | 09:28 AM
mattmo78's Avatar
Originally Posted by MrWesson
Seems to be the way to go.. It looked darn near factory.. IMO would only work for the front bumper though.
I have a pic which I will post later of one I looked at that had this setup.
I'm curious to see what it looks like. Please post when you can.
Old Mar 10, 2014 | 12:27 PM
earlyrover's Avatar
Other than the fiberglass resin (which is available in any good hardware store, standard fiberglass resin and hardener) repair, which I did, successfully, another option, which I almost did, for bumpers cracked or broken in center top area of bumper, is as follows:
Buy a section of aluminum sheet (not sheet metal, but of heavier thickness, say about a full 1/8" thick, or slightly thicker, but not as much as 1/4" thick), cut it to size, so that is is just wide enough to fit over top of middle section of bumper, and long enough to cover over the crack or break, with enough extra room on both sides, extending out about a foot or so on each side of crack/break (for strength, overall), center it, drill it for bolts that will go down through aluminum plate, through plastic bumper, with bolts just long enough for big washer and nut on other side of bolts, to secure the aluminum to plastic bumper, holding it all together as a whole unit. That will provide added strength, where needed, on bumper, look nice overall. Now, when done, paint it all as one unit, aluminum plate, centered, and bumper. This will give plenty of strength in a weak area of bumper, will look good, aluminum strengthener piece is centered, balanced, strong, strengthening plastic where needed.
Old Mar 10, 2014 | 12:42 PM
MrWesson's Avatar
Old Mar 10, 2014 | 12:59 PM
Madlands's Avatar
Got any after pictures of your aluminum sheet method earlyrover?
Old Mar 10, 2014 | 01:37 PM
earlyrover's Avatar
__________________________
No, as I wrote in explanation, I didn't do this, but did the fiberglass repair mentioned earlier. However, I did buy a section of aluminum, shop cut to size, as explained in that alternative repair method, because I originally intended to use the aluminum for repair, until I opted for the fiberglass method. Too, I thought about doing both the fiberglass AND the aluminum together, making for way more strength than necessary, but for a "come hell or high water" repair. I still have aluminum piece, and may use it for something else, unless someone backs into me and breaks the fiberglass---unlikely, as I now have a nice brush guard I installed on front end too.
goshowfamily
May 9, 2020 05:51 AM
dobe1canobe
Jan 26, 2015 12:29 PM
real_tea
Feb 23, 2013 02:47 PM
tweakrover
Oct 11, 2009 09:55 AM
disco12
Jan 10, 2006 09:50 PM
