Anyone replaced a torque converter?
If you're replacing the torque converter, you really should replace/rebuild the trans and flush out the tranny cooler lines at the same time. The debris from your old converter will have gone through the entire system.
That was the plan, but the rebuild kit costs as much as a whole transmission from a wrecker. I'll see what shows up on the filter, but it's hard to justify paying $400 for a few gaskets.
I don't have issues with the mechanical part. It's mostly the financial side of thing.
Also on another note, why does a rebuild kit for the hp22 doe a bmw cost half as much ase the one for LR? They seem to be pretty much identical...
If it’s a 4HP24EH then it’s the same trans. BMW also used the 4HP22, which I think is a D1 trans. Either way, the kits should be the same for their respective transmissions.
