Anyone replaced a torque converter?
Old Jul 22, 2023 | 02:21 PM
miron's Avatar
Default Anyone replaced a torque converter?
If anyone has replaced the torque converter, I'd really appreciate any pointers on how and what should I be looking out for.
thanks!
Old Jul 22, 2023 | 11:48 PM
sdtimb's Avatar
I haven't, but the instructions should be in the RAVE (D2 workshop manual). Do you have a copy?
Old Jul 23, 2023 | 12:02 AM
miron's Avatar
I do have a copy, but you know there are always some special tricks etc.
Old Jul 23, 2023 | 06:55 AM
Alex_M's Avatar
If you're replacing the torque converter, you really should replace/rebuild the trans and flush out the tranny cooler lines at the same time. The debris from your old converter will have gone through the entire system.
Old Jul 23, 2023 | 12:27 PM
miron's Avatar
That was the plan, but the rebuild kit costs as much as a whole transmission from a wrecker. I'll see what shows up on the filter, but it's hard to justify paying $400 for a few gaskets.
Old Jul 23, 2023 | 02:37 PM
Extinct's Avatar
Alex_M is right, just swap the entire transmission. They almost never go out,better use of your time and money to just swap it.
Old Jul 23, 2023 | 03:10 PM
miron's Avatar
Yes, sorry the "rebuild" somehow got stuck in my head. Replace is definitely a viable option.
Old Jul 23, 2023 | 05:46 PM
Richard Gallant's Avatar
@miron If you doubts have it done by a shop, Automatic transmission and brakes if you are not sure get it done professionally.
Old Jul 23, 2023 | 05:50 PM
miron's Avatar
I don't have issues with the mechanical part. It's mostly the financial side of thing.
Also on another note, why does a rebuild kit for the hp22 doe a bmw cost half as much ase the one for LR? They seem to be pretty much identical...
Old Jul 23, 2023 | 08:03 PM
ahab's Avatar
If it’s a 4HP24EH then it’s the same trans. BMW also used the 4HP22, which I think is a D1 trans. Either way, the kits should be the same for their respective transmissions.
