Anyone using the Cen-Tech 60794 OBD+ABS code reader ?
Hi.
Got one today from Harbor Freight. Can anyone guide me how to update it, in order to list LandRover in its vehicle menu ?
And any other details I should know ?
Thanks.
Thanks.
Hi.
Updates about this Cen-Tech 60794 OBD2+ABS reader as many would like to know.
OBD2 works well on 2000 Disco. European ABS lists only Mercedes, Audi, BMW, Mini.
The manual tells to update it at HarborFreight web site.
Nowhere in that site there is a thing about it.
-Asked both customer support and technical support on email. Of course, no reply after a week.
-Called technical support on the phone: after 20 minute wait of the bulldung "all our representatives are busy" a recording tells to do it via the web; which I had done it twice already.
-Called customer support on the phone; the guy is lost in space. Asked him to contact Centech for update guidance. Another week of silence.
Returned to the store today. End.
Total: remove this scanner from the options list to buy. Does not work with LR brakes, and the service from HarborFreight works even less.
Edited: added---> This Cen-Tech 60794 seems identical to Autel MS609
Correct. Another set of careless chinese-style geniuses from Autel there.
The downloadable "update" does not tell anywhere which version/date/library it is, being entirely possible that the download may be the same the unit already has, or, even worse, an older one, as the Autel MS609 is declared "Old" in that same link.
So you would be forced to blindly download crappy .rar 33 megabyte compressed files that can end in update failure leaving the tool non-operational. And if you run only Linux like me; chances are nothing will work with 'Windows XP requiered' as somewhere hiding in fine print states
The Centech 60794 I just returned had "Burn" 02/26/13 ; Software ver 3.80 ; for Hardware ver 1.0 ; and Library ver 2.00
So a seven month old unit is already unsupported.
I wish to be wrong but found nowhere solid data telling that can be made to work with Disco 2
Go to barber freight and pull up the code reader then look at bottom where it shows description there is a tab for update and manual click an update and the click on the link to download the update file then after installing the cd open the program it will show you more than one model on the left click on your model the to the right of that on left side of the window it will have a print and under it an update tab plug your reader into computer turn it in scroll to the update system and hit enter then on the computer screen click the update tab then click the brouse button you need to go to the files you just downloaded from harber freight and click on the .bin file then once file name is in the little address line under it you will see the update tab click on it and it will update your reader... Do the same with the Dtv update as well it will be a .aut file extention
Hope I have helped!!
rotaryla
rotaryla
S/W :v4.03
H/W: v1.00
LIB ver: v3.02
Do i have to update or I am on the most recent version?THANKS
