Anyone who's replaced front shocks,
Old Jun 13, 2011 | 09:02 AM
kenk's Avatar
Default Anyone who's replaced front shocks,
do you have to pull the shock tower as rave instructs? Or will the lower mount fit through intact?
Old Jun 13, 2011 | 09:28 AM
dcarr1971's Avatar
Pulling the towers is really pretty easy and doesn't take long at all. IIRC, it's 4 bolts + the bolts at the top and bottom of the shock itself.
I don't think you'll be able to get the shock in there with the spring around it unless you're pulling the tower.
Old Jun 13, 2011 | 10:57 AM
yloDiscoII's Avatar
Yup...gotta pull the towers. Its a bit of a PITA to fish them through the engine compartment, but it is very straight forward. Lining up the lower shock mounts when you're refitting can be a bit of a challenge as well, if you can recruit a helper, do so.
Old Jun 13, 2011 | 11:56 AM
sloan74's Avatar
You got access to a lift? Make's it a lot easier...
Old Jun 13, 2011 | 01:42 PM
kenk's Avatar
Nope, my lift is a floor jack and stands. I did the springs and shocks on my '98, I was just hoping the different tower design on the '04 would mean not having to pull them. Oh well.
Old Jun 13, 2011 | 02:27 PM
hilltoppersx's Avatar
the front is worse than the back. but yes have to pull
Old Jun 13, 2011 | 07:17 PM
kenk's Avatar
Well, if I got it that far apart, what better reason for new lift springs too....
oljohnboy
Apr 1, 2014 01:45 PM
sayeedA
Apr 23, 2012 09:00 PM
Cal
Jan 28, 2011 06:06 PM
Bryan H
Oct 3, 2010 09:48 AM
