Apparently it was about time the bearings were replaced
Old 09-28-2017 | 06:50 PM
Blacktt3z's Avatar
Default Apparently it was about time the bearings were replaced
Yikes
Old 09-28-2017 | 08:54 PM
Jeff Blake's Avatar
Worn indeed. Mine looked about the same, with 105k miles. It's only the top half of the shell that seems to get worn excessively.
Old 09-28-2017 | 10:09 PM
Alex_M's Avatar
Hmm, maybe time I replace mine at 147k. We'll see. Probably save up and do piston rings and maybe some 4.0 pistons at the same time.
Old 09-28-2017 | 10:20 PM
Jeff Blake's Avatar
pistons should not need replacing unless they fall out of spec and/or the bore needs to be bored out to size “b” pistons
Old 09-29-2017 | 07:36 AM
Alex_M's Avatar
Righto, but 4.0 pistons stand a hair taller so it would bump the compression just a touch and give just a little more power.
Old 09-29-2017 | 09:37 AM
Blacktt3z's Avatar
Just an fyi replacing the cam bearings bumped my hot idle psi from 4-5 up to 12 psi. The rod bearings bumped it up to about 18-20 hot idle.
Old 09-29-2017 | 10:00 AM
Sixpack577's Avatar
Was the engine in or out when you replaced cam bearings? I know it can be done with the engine in the truck, but that looks like a major pain in the *** to do.
Old 09-29-2017 | 10:03 AM
Sixpack577's Avatar
Main bearings look like a pain to do in the truck too.
I'de hate to do rod bearings and not mains too, or the cam bearings. Rod bearings look easy with the engine in the truck.
I'm chasing a tap/knock that I doubt is any bearing. But I may bite the bullet and do them anyway, before saying for sure I have a slipping liner (s).
Old 09-29-2017 | 03:08 PM
Blacktt3z's Avatar
In the truck. Big pain in the ***
Sixpack577 (09-29-2017)
Old 09-29-2017 | 03:15 PM
Sixpack577's Avatar
Lol, got any details?
What puller and drive you used?
I assume you had noise before and none after?
Did the cam look bad?
Thanks
Quick Reply: Apparently it was about time the bearings were replaced
