Apparently it was about time the bearings were replaced
Old Sep 29, 2017 | 04:38 PM
KingKoopa's Avatar
Damn, another walked cam bearing? I wonder how many discos are running around with a "tick" and a lifter eating through a cam bearing?
Old Sep 29, 2017 | 04:39 PM
Blacktt3z's Avatar
Originally Posted by Sixpack577
Lol, got any details?
What puller and drive you used?
I assume you had noise before and none after?
Did the cam look bad?
Thanks
i just used a cheap $80 summit cam bearing tool, it worked perfect actually. Honestly there was only a light tick when it was fully warm and I'm guessing that was the lifter eating away the cam bearing that walked. Cam was fine but I replaced it with a higher lift crower cam and oem lifters.
Old Sep 29, 2017 | 04:41 PM
Blacktt3z's Avatar
probably a lot. The oem cam bearings have a weird design, they aren't solid. They're split at one point and have a little joint, it's hard to explain. I'm sure that contributes to them walking. The aftermarket bearings I picked up look like they were much higher quality and completely solid.
Old Sep 29, 2017 | 04:54 PM
Sixpack577's Avatar
Any noticeble improvement with the new cam?
Old Sep 29, 2017 | 04:55 PM
KingKoopa's Avatar
Yeah I know what you mean, very weird design.
Good to know the aftermarket units are solid.
Now I'm irritated though, willing to bet I've got the same issue and I'll be damned if I'm stripping the thing down to a short block only to change the bearings... ugh
Old Sep 30, 2017 | 11:04 AM
Blacktt3z's Avatar
a little low end grunt, nothing too crazy.
gillart
May 26, 2015 11:25 PM
LandRoverDisco03
Jan 31, 2015 11:56 AM
Elspode
Jul 19, 2013 10:20 PM
LRD2&ME
Sep 4, 2011 10:23 PM
Baylink
Apr 11, 2010 01:51 PM
