ARB compressor location?
Old Jul 14, 2014 | 10:14 PM
vette427sbc's Avatar
Default ARB compressor location?
For those of you with air lockers or small on board compressors, where did you mount them? Under the hood? In the cabin? Pics?
I was thinking of putting mine where the factory jack is but Im unsure if the underhood heat and outside elements will kill it or not.
Old Jul 15, 2014 | 07:57 AM
primussucks's Avatar
Buddy of mine put his in the rear of his vehicle. If you take the little vent out at the far right/rear, there is plenty of space. This would be opposite side if you have rear A/C. Works very well... there is easy access to the underside (for connecting to your lockers) and he even put a air jack right out the side of the below the tail light.
Old Jul 15, 2014 | 09:33 AM
ZGPhoto's Avatar
Mine is mounted on a custom bracket inside my passenger side rear storage bin. I also have an air chuck in my fuel filler door for easy access.
Old Jul 15, 2014 | 02:20 PM
Yoops Racing's Avatar
I mounted mine there as well with a bracket that holds it down. I did not want the heat or the elements to get to it.
Old Jul 15, 2014 | 05:24 PM
Behind the passenger rear compartment vent was my second choice... So thats a no-go under the hood eh?
Old Jul 16, 2014 | 10:43 AM
Good luck finding room..especially if you have SAI
Old Jul 16, 2014 | 10:44 AM
ZGPhoto's Avatar
You could, but it gets so hot under there that I never would. A buddy has melted several air lines with his under the hood
Old Jul 16, 2014 | 11:47 AM
dusty1's Avatar
Sls compressor bracket on frame, where mine be.
Old Jul 16, 2014 | 12:35 PM
ZGPhoto's Avatar
then I feel bad for you son....
because I got 99 rover problems, and mud in my compressor aint one
Old Jul 16, 2014 | 12:43 PM
dusty1's Avatar
Ha. Well I did use the little plastic box that covered the sls one.
