Argg Trying to defeat the 3 Amigos for Good!
Hello All,
Here is a little back history on this story. I have performed option B, bled the brakes 2x. Added new shuttle valves(fixed the issue back in January). Also just installed new Seals from Falcon works. Passed the Ohm test on the Shuttle valves. New pads rotors all 4 all the way around on the Rover. Basically I still have the 3 Amigos constantly, never turn off. And the Brake light is on constantly.
Brake fluid level is full. What are next steps to fix this issue? I also have 1590 rough road code about 2x a month.
I am leaning toward doing Option A. Its my last resort. I do have a spare ABS modulator off eBAy. Here is the ABS Amigo print out. I also am going to find a friend with a know good master cylinder cap to swap out and try.
1.--Current Faults---->
Active Faults:
None
Logged Faults:
None
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
016:Shuttle valve long term fail
Front Right Sensor Bad Output
114:Shuttle Valve Electric Failure
<-END Faults
Active Faults:
None
Logged Faults:
None
<-END Faults
Active Faults:
None
Logged Faults:
None
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
None
<-END Faults
Well after scanning with ABS Amigo this moring I started my car and the ABS light hung for 2 sec then no more Amigos. Brake light is even out. I must have cleared the codes with the ABS Amigo. I'll keep my fingers crosses that the seal fix worked.
I don't understand how the option A could work since that post that sticks out is no longer connected to the shuttle valve wires. Any thoughts
Update:
After about 2 days of Amigo free driving they came back this morning. Here is the scan data. So the shuttle valves are about 6 months old, but did have some slight brake fluid on them before I fixed the seals this time. They passed the Ohm test on my meter. So whats next? As Jasfar said do not do option A, since I did option B. Roger That
My ABS is working for last 3/4 days now. I tested it in Hill decent mode as was fine going down a slight decline. I'm temped to put my test ground wire back to the grounding block.
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
None
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
None
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
cammyr01
01-05-2015 02:42 AM
ljdiscovery
08-12-2009 01:58 PM
flyingalexf68
05-09-2006 01:51 PM
discoseeker
02-28-2005 05:55 PM
