Trying to bleed brake fluid. Can you help?
Old Apr 30, 2006 | 04:51 PM
flyingalexf68's Avatar
Default Trying to bleed brake fluid. Can you help?
Hi,
I'm having difficulty bleeding the brake fluid out of my 1996 DSE. I had to replace the ABS valve unit and I can't get the brake fluid to bleed for me. There are three nipples on the side of the valve block. Do you know which one I should use.
Thanks for the help.
Alex.
Old May 9, 2006 | 01:51 PM
Default RE: Trying to bleed brake fluid. Can you help?
Alex,
I can't help you on bleeding the block but make sure to bleed the brakes when your'e done.
Mike
Alex_M
Apr 1, 2015 10:11 AM
calebbo
Oct 12, 2011 09:54 PM
JavaDiscoII
May 29, 2010 04:33 PM
lipadj46
Jul 11, 2009 08:52 AM
ste
Mar 23, 2007 06:47 PM
