ARP studs install question
on
The debate of head studs vs tty bolts is nearly as heated as your choice of oil, politics or religion.
But if you have instant failure on either method of holding down your head gasket your installer or your machine shop screwed up.
When using bolts I feel that it’s important to mark the bolts after doing the first torque with the torque wrench. The odds of slipping off on one or two of the bolts is high. If you didn’t mark them you won’t know where you’re at. I also put a piece of plywood on the windscreen to prevent me slipping off and smashing it.
JohnZo (02-24-2024)
